dirtpig538
- Joined
- Mar 28, 2010
- Messages
- 95
My axles are worn where the seal and bearing run. What other model axles will fit?
Do yourself a huge favor, jack up the machine & pull on each wheel; inward & outward. As long as there is NO movement, then you should only NEED a new seal. I would suggest replacing all four (4) of them at the same time, though. If one of them is leaking, then my thinking is that the other (3) are probably leaking or very close.Just how bad is the wear? even a small lip will still seal, you can some times knock the seal in a bit further to get good metal to seal on. Even a speedi-sleeve could do the job.
