bobcat743b
- Joined
- Jun 15, 2019
- Messages
- 75
can someone tell me the part number for the hydraulic filter on the right side of engines compartment.' thanks
The best way to get OEM part numbers is to go to Bobcat Parts Online. If you have your serial number handy, put it in the search tab and it will pull up all relevant pages, otherwise go to the model tab and go through the menus.also good recommendation where i get one or a cross reference number. thanks
Thanks. found the number and found one on ebay. thanks again.The best way to get OEM part numbers is to go to Bobcat Parts Online. If you have your serial number handy, put it in the search tab and it will pull up all relevant pages, otherwise go to the model tab and go through the menus.
Once you have the OEM number, you can google it and find online sellers. In the case of filters, that should easily cross reference to a Baldwin or Wix number that can be sourced at almost any parts store.
For completeness, you can get the NAPA "Gold" 1482 filter or the Donaldson P164384.Thanks. found the number and found one on ebay. thanks again.
