Bobcat Skidsteer Forums
743b won't start. need advice.
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 45689" data-attributes="member: 82"><p>Make sure you bleed the fuel system, open the screw on the injector pump and squeeze the hand primer. CLose the screw and see if it starts better.</p><p>It should never need ether to start, glow plugs should be enough..... Are they getting power?</p></blockquote><p></p>
[QUOTE="Tazza, post: 45689, member: 82"] Make sure you bleed the fuel system, open the screw on the injector pump and squeeze the hand primer. CLose the screw and see if it starts better. It should never need ether to start, glow plugs should be enough..... Are they getting power? [/QUOTE]
Verification
Post reply
