743B U joint
wbecker
After getting the aux hydraulics connected and all other items working good, I cleared driveways in the winter, bought a rake grapple and got a lot of work done. Then yesterday I used it and sprung a leak in the line that goes in front of the engine down on the bottom, I knew it was rusty and was not surprised. I pulled the engine out to replace the hydraulic line and need a part # and source for a new U joint, Bobcat wants $207.80. I didn't see one at loaderpartssource.com is there another place I can look for a better price? Thanks, Bill B
That seems like the kind of thing that LPS would carry. Did you try giving them a call?
auto parts store here can get them but watch the grease fitting placement. You want one that greases from one of the bearing ends not in the center of the cross. When I got one I ended up at bobcat , about the same price at that time.
I bought mine from loadersource parts for about a hundred bucks but four of the bolts were a bit too long and put it in a bind whatch for this easy to miss and it will tear things up don't forget the blue locktight
I did the samething and would suggest that you replace three lines two at the bottom where the cross and the one in the shrould
