I have a lot of noise and excess forward and backward movement on the right rear wheel. How do I expose enough of the chain case to access the rear spockets, should I need to replace one. Thanks in advance
To access the rear chains/sprockets you really need the inspection cover under the pump. Sadly its not easy to access. Hopefully its only the chain that has stretched.
There have been a couple of members that have actually seperated their chain case from the machine to work on it. There are about 12 bolts that hold it to the frame. You then have the hoses to the drive motors. Two bolts holding one side of the hydro pump and the arm that controls lift/tilt. It will give much greater access to the internals of the chain case.
