wbecker319
- Joined
- Oct 22, 2013
- Messages
- 34
I checked the glow plug ohms, all are ok, 1-2 ohms. Traced out and fixed wiring problem, installed a new glow plug relay, now the glow plugs work, but take way too long. It takes well over 1 minute at 60 deg. and still doesn't start quickly. Can glow plugs need replacing even if they check good with the ohm meter? I use a very small shot of ether in the air filter and it starts very quick. The previous owner always used ether. I have not checked compression, suspect may be a little low causing the problem, but I'm not ready for an overhaul. I just want to use it for light work on my 6 acres occasionally, and should last me a long time. I was wondering about installing an ether system, operated from the cab, it would be so much more convenient. Any thoughts on this idea?
