Help please. How can I override the ignition switch so I can start it and move it. I purchased a new ignition switch, but it is totally different than my original ignition. I just want to hot-wire it and get it moved. P.S. It's diesel. Thanks. Russ
If that fails, cable tie on the shut off solenoid so it's in the run position, screw driver to jump the starter, +12 to the small pin on it and it will crank and start.pretty simple. Red/White - 12vdc Blue/Black - glow White = starter Orange and blue wires = switched power
Hello...thanks for your response. I need some additional help. I have 2 orange wires and the blue black for the glow plugs is only blue...no black. where do they go on the ignition switch? I took some pictures that I could share with you, if you could email me directly. [email protected] Thanks so much. I really appreciate it.pretty simple. Red/White - 12vdc Blue/Black - glow White = starter Orange and blue wires = switched power
straight blue needs to tie to switched power with the orange. That connects to the optional shutdown system. I believe the prints show this as 26 and 26A. Blue/Black is glowHello...thanks for your response. I need some additional help. I have 2 orange wires and the blue black for the glow plugs is only blue...no black. where do they go on the ignition switch? I took some pictures that I could share with you, if you could email me directly. [email protected] Thanks so much. I really appreciate it.
