Bobcat Skidsteer Forums
743B alternator issues
Reply to thread
Message
<blockquote data-quote="Centurion" data-source="post: 16464" data-attributes="member: 1813"><p>If I walk up to the bobcat and look at the center of the Hub, it is welded, no bolt. I called bobcat, gave them the serial# and they told me it was a 743B, from what you say, and what I have been reading, it sounds like it is not a 743 B. As far as the alternator, I have tried checking things with a voltmeter, and there is no charge whatsoever while the engine is running. I think I will go with the delco, if someone can tell me exactly what I need to get, it seems like an easier solution.</p></blockquote><p></p>
[QUOTE="Centurion, post: 16464, member: 1813"] If I walk up to the bobcat and look at the center of the Hub, it is welded, no bolt. I called bobcat, gave them the serial# and they told me it was a 743B, from what you say, and what I have been reading, it sounds like it is not a 743 B. As far as the alternator, I have tried checking things with a voltmeter, and there is no charge whatsoever while the engine is running. I think I will go with the delco, if someone can tell me exactly what I need to get, it seems like an easier solution. [/QUOTE]
Verification
Post reply
