Bobcat Skidsteer Forums
743 won't start in the cold
Reply to thread
Message
<blockquote data-quote="kyosho" data-source="post: 72658" data-attributes="member: 3504"><p>I ordered a Kats 13200 tank inline heater from amazon today. From what I can gather - remove the drain plug from the block and replace with a nipple. 5/8" hose from there to the heater. Strap around the heater and bolt it to something. The short bypass hose that is 3/8" that is near the upper radiator hose/thermostat housing - cut that in half and put a 3/8 x 3/* tee in it. 3/8" from there into a 5/8" and back to the outlet of the tank heater. I have to run it it says to purge air so not sure how I can do that when I can't get it started. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite2" alt=";)" title="Wink ;)" loading="lazy" data-shortname=";)" /></p></blockquote><p></p>
[QUOTE="kyosho, post: 72658, member: 3504"] I ordered a Kats 13200 tank inline heater from amazon today. From what I can gather - remove the drain plug from the block and replace with a nipple. 5/8" hose from there to the heater. Strap around the heater and bolt it to something. The short bypass hose that is 3/8" that is near the upper radiator hose/thermostat housing - cut that in half and put a 3/8 x 3/* tee in it. 3/8" from there into a 5/8" and back to the outlet of the tank heater. I have to run it it says to purge air so not sure how I can do that when I can't get it started. ;) [/QUOTE]
Verification
Post reply
