Bobcat Skidsteer Forums
743 wheel bearings
Reply to thread
Message
<blockquote data-quote="dStar" data-source="post: 43354" data-attributes="member: 5591"><p>If you're still looking for bearings, I got these Timken part numbers from another member on this site. I haven't confirmed them yet, but he said that for each axle you'll need 2 of part number LM104949 and 2 of part number LM104912. If you shop around online, you should be able to get all four for under $50 per axle (which is about half of what my local dealer is charging). Don't forget to pick up a seal for each axle (National part number: 40301S). I don't remember what the dealer was charging, but these are only about $15 each online and you can usually buy them from the bearing supplier to combine shipping costs. Good luck! -Paul</p></blockquote><p></p>
[QUOTE="dStar, post: 43354, member: 5591"] If you're still looking for bearings, I got these Timken part numbers from another member on this site. I haven't confirmed them yet, but he said that for each axle you'll need 2 of part number LM104949 and 2 of part number LM104912. If you shop around online, you should be able to get all four for under $50 per axle (which is about half of what my local dealer is charging). Don't forget to pick up a seal for each axle (National part number: 40301S). I don't remember what the dealer was charging, but these are only about $15 each online and you can usually buy them from the bearing supplier to combine shipping costs. Good luck! -Paul [/QUOTE]
Verification
Post reply
743 wheel bearings
