Bobcat Skidsteer Forums
743 vs 763F
Reply to thread
Message
<blockquote data-quote="BobCat" data-source="post: 55864" data-attributes="member: 582"><p>I've owned both models and liked both. The 763 pros are more lift capacity, auto glow, quick to start, higher gpm hydraulic flow, stable wide base, liked the belt drive setup making it easier to get to engine for service, just to name a few. Cons, didn't like how the blower blasted the ground with air causing a dust cloud around where I was working and I didn't like the auto park break. I would forget to release it and I can see how after a few times you could easily break it if you weren't idled down when you run into it, and the 763 uses more fuel. Other than lifting capacity and a nearly impossible to grease U joint I can't say much bad about the 743. Love mine!</p></blockquote><p></p>
[QUOTE="BobCat, post: 55864, member: 582"] I've owned both models and liked both. The 763 pros are more lift capacity, auto glow, quick to start, higher gpm hydraulic flow, stable wide base, liked the belt drive setup making it easier to get to engine for service, just to name a few. Cons, didn't like how the blower blasted the ground with air causing a dust cloud around where I was working and I didn't like the auto park break. I would forget to release it and I can see how after a few times you could easily break it if you weren't idled down when you run into it, and the 763 uses more fuel. Other than lifting capacity and a nearly impossible to grease U joint I can't say much bad about the 743. Love mine! [/QUOTE]
Verification
Post reply
743 vs 763F
