oracle_of_ferndale
- Joined
- Feb 12, 2013
- Messages
- 78
My 743 is still stuck on start. I swapped out the engine. After putting everything back together, when I touch the ground cable to the battery, sparks fly and the starter spins. I replaced both starter solenoid relays. Something else must be wrong. When I disconnect everything except the cable from the battery to the starter (not running through the relays), it still sparks and spins. Could it be a problem with the ground? The starter? Seems like this should be obvious to someone smarter than me... Is there a surefire way to get the machine grounded properly? Thanks for any suggestions.
