I lost the drive to one of my rear wheels. Opened it all up expecting to find a broken chain. Nope , the sprocket had sheared off the axle coupling. Everything else looks OK and it didn't do any other damage. Strange thing is it looks like the weld on one side has been ground down? Priced a new sprocket at $420. Questions are; Can the sprocket be welded back on to the coupler with an outcome of reasonable durability for a machine that only sees occasional use? Does the axle have to pulled partialy out to reinstall the sprocket? Was able to drive a pin out of the chain to seperate it and wondered if the old pin could be reused and just hammered over with a ball peen and a heavy backer to resecure the chain link. The book says to tighten axle bolt to 425 ft lbs, can that be right? Is a 6 piont 1&1/8 box end needed to remove the axle bolt or will a 12 piont do? Any experience in this area would be welcome info.
