Bobcat Skidsteer Forums
743 positive battery cable to ground
Reply to thread
Message
<blockquote data-quote="mahans7" data-source="post: 57765" data-attributes="member: 7824"><p>I put a remanufactured Delco 10SI(3 o'clock/61 amp) alternator on today and reconnected the 2 wires to the starter solenoid and the dash indicator light. The voltage reading was 14 volts and the dash light worked. The bobcat will be run on dirt/grass with occasional short straight runs on asphalt between sites. Thanks again guys for all your help.</p></blockquote><p></p>
[QUOTE="mahans7, post: 57765, member: 7824"] I put a remanufactured Delco 10SI(3 o'clock/61 amp) alternator on today and reconnected the 2 wires to the starter solenoid and the dash indicator light. The voltage reading was 14 volts and the dash light worked. The bobcat will be run on dirt/grass with occasional short straight runs on asphalt between sites. Thanks again guys for all your help. [/QUOTE]
Verification
Post reply
