greenweenie
- Joined
- Sep 27, 2016
- Messages
- 6
Hello to all, again. I am tearing down and doing any maintenanceon 743 i can do before wood splitting and snow plowing. I am trying to figure out how to get the parking brake assembly out. My pucks are wore out and W shaped holder is rubbing on the discs. I have the first cover off so I can inspect and change oil. I removed the parking brake pedal, rod and lever. I have removed the bolts that hold the brake holder cover, but the plate will not lift out do to clearances to both the pump bracket and the steering linkage. Wanting to know If i take out the bolts that hold the parking brake will i be able to get it out that way? looks like it might not clear the discs. Other wise do i have to remove all the other parts to get out. Manual doesn't give a break down on how to do it, just says take it out. Thanks Also does any one know if this machine has a float feature? When my dad owned the bobcat dealer said it was broke. Not sure what to look for. Thanks, Nate
