Bobcat Skidsteer Forums
743 ignition question
Reply to thread
Message
<blockquote data-quote="newy1234" data-source="post: 46087" data-attributes="member: 5611"><p>If you check it all and determine it is just the key switch that is faulty, I would get a price for a new one from you local bobcat dealer. I would assume they are not that expensive.</p><p>Then all you have to do is replace the switch and you will not have the butcher any wiring.</p><p>As Tazza said, to activate the glow plugs the key turns to the left and you hold it, then to activate the starter motor you turn the key to the right.</p></blockquote><p></p>
[QUOTE="newy1234, post: 46087, member: 5611"] If you check it all and determine it is just the key switch that is faulty, I would get a price for a new one from you local bobcat dealer. I would assume they are not that expensive. Then all you have to do is replace the switch and you will not have the butcher any wiring. As Tazza said, to activate the glow plugs the key turns to the left and you hold it, then to activate the starter motor you turn the key to the right. [/QUOTE]
Verification
Post reply
