743 hydraulic issue
Sparky87
Hi all, new here. Just picked up an 86 743. It's in decent shape, needs some love. The first thing on my list is an issue with the lift arms drifting down. The hydraulic power seems to be fine although I haven't had a chance to load the bucket down yet, however when I raise the lift arms they start to drop as soon as i let off the pedal. I know it's low on hydraulic fluid and I need to change it. Other than that I don't see any obvious signs of leaks. Could that be a symptom of a valve spool needing seals? The lift cylinders don't show signs of leaking. Just hoping someone can point me in the right direction. Thanks
Why won’t my 743 start after replacing the lift cylinder? Fluid to low? Safety switch somewhere? Ran fine when parked to replace seals, now nothing happens when I turn key!?
Did you raise the cab at all? Could be the harness became unplugged. Not sure if the 743 is the same but on the 732 there's a double rectangular plug where the cab meets the main frame on the bottom left back corner of the cab as you're sitting in the sear and chances are that one or both might have unplugged themselves? Just a thought...
Worn piston seal rings in boom cylinders or spool valve is worn bypassing.
You can check by raising boom and capping hydraulic ports on pressure side of cylinder ( non rod side) only leave the rod side hose on . See if it drifts down . If it does rebuild cylinders. If not control spool valve worn orings seals are bypassing .
Per Catterpillar one would use a temperature gun after running the unit for around 10 minutes raising and lowering the bucket, lifting a load would be best the cylinder that is leaking is going to be warmer by about 10 to 20 degrees depending upon the bypassing in the cylinder.
The tollarance on a spool valve is such that the film of oil on the spool is the high pressure seal, the O ring is just a wiper to keep most of the dust and dirt out and they should be changed when they start to leak a lot.
