Other than going to bobcat and ordering one, is there a good source of supply for one? Or one that will work? I was thinking the old Ford pickup starter solenoid that was mounted up above wheel well would work just fine). I have battery voltage coming into the relay but nothing goes out. The energizing coil has battery voltage reaching it, when the switch is turned to "heat" ground is applied. No reaction from the relay.
