One blade out wouldn't reduce the air flow enough to be an issue, if balance is, you can remove a blade 180 degrees from the missing one, it should get it pretty close to being right. I believe a new blower/flywheel will set you back a few dollars....The cooling fan on a 743 is the flywheel. To work on it the engine has to come out.
