I have a 743 that drives straight ahead and backwards fine. I can also turn right with no problem. When I go to turn left sometimes I get no movement. If I play with the controls the machine will jump hard to the left. Sometimes it will then engage the left side wheels and I can see that they are going in reverse with power. I put machine on blocks and notice that when I go to the left the wheels on the left side of the machine aren't turning and the ones on the right are. When I turn to the right I see that both sets of wheels turn. If I play with controls I can get them to go. Sometimes they go and they are moving at a slower speed than the other side. I've taken the pressure valves or I guess they're called relief valves out of the side of the pump (2 on each side - under caps - they have springs. There are 2 different pieces. One looks more like a relief valve and the other looks almost like a blank valve) I swapped them from side to side and the problem stayed on the left side. I am thinking shuttle valve could be problem, but not 100% sure. I haven't taken it out yet. Can a shuttle valve be causing this type of problem? Is it ok to just pull the valve out while the motor is still installed in the machine? Could it be a broken spring or some trash caught on the valve? Any help is appreciated. Thanks, Ken
