G'day everyone, I have a bit of a problem with my 743. I will be ordering a bronze filter for it today to see if that makes a difference however am not convinced it will. The problem started after I repaired the mount for the top pin on the tilt ram and one of the fittings on the tilt ram that was sheared off when it let go. I drove the machine back to the truck and loaded it with no drive issues what so ever. Over the next two weeks I did a lot of cutting grinding and welding to piece it back together. The machine lost a bit of fluid in this time however I would say only about 4 litres max. when I put it back on the tilt ram was pretty well empty. So happy with my repairs I drove the Bobcat off the truck and once on the level ground it started getting noisy and hard to steer so I put some oil in it and tried again. This time it went ok for about 30 seconds then went downhill to the point where the levers would go slack and not do anything then I could feel a surge through them and they would regain "feel" but would be extremely hard to steer and noisy and wouldn't last long before going slack again. When I shut it down I can hear glug glug glug in the hyd. tank. Lift is a bit chattery sometimes but works, tilt is fine and machine worked fine before repairs, any suggestions would be greatly appreciated. Thanks in advance.
