743 Dipstick ?
Unibomber
Can anyone come up with a part# or link to a replacement oil dipstick for 743 with V1702 puurdy please ?? Thanks
before buying your dip stick , ask the dealers parts man if your machine required the upgrade on the dipstick , I don't know if this is what happened to you but there was a problem with the dip stick of early Bobcat Kubota getting hooked up on the crankshaft and getting all bent up , I seen them where I had to really work to get them out and a few that broke off and fell into the bottom of the oil pan , so Bobcat came out with a sleeve / extension that knocks into the block , then you use a longer dip stick , the tube makes sure the dip stick goes straight in and not to the side where it gets hung up , so the replacement dip stick is a bit longer and calibrated to match the extra lenght of the tube
I see no BTI attached to this part #
If you can believe it I lost mine :( Took it out when doing some work, it leaked anyhow and I planned on getting a new one or putting a new rubber o-ring on to try and tighten the fit, but now I need a new one. I will try the part# thanks !
..........you think the leaking could be from excessive blow by , have you put your thumb over the end of the blow by tube lately , I have seen the dipstick blow out the engine when doing this on machines with bad compression ................
