Bobcat Skidsteer Forums
743 cooling system
Reply to thread
Message
<blockquote data-quote="skidsteer.ca" data-source="post: 26345" data-attributes="member: 307"><p>I don't like the spiral wound flex pipe for exhaust, unless you can get stainless, the steel variety rust out to quick and leaks severely.</p><p>I have never done it for a skid but on our larger equipment we have had pipe bent up or bought elbows and cut them to the correct angle to fab up exhaust for the float truck (ford was 2200.00, we made ours for 600 worth of parts and a days welding. and for the skidders.</p><p>I also did one for the 16 hp onan in our miller welder, 300.00 for a new muffler, I just cut it open and built one from a couple different diameters of pipe with the same design. I had to drill alot of hole in the inner pipe to make a baffle, but 10 years later its still going.</p><p>Do call a few different dealers as prices on oem parts do vary alot. I have had good luck with <a href="http://www.BarronSupplyco.com" target="_blank">www.BarronSupplyco.com</a> in Barron Wi</p><p>Ken</p></blockquote><p></p>
[QUOTE="skidsteer.ca, post: 26345, member: 307"] I don't like the spiral wound flex pipe for exhaust, unless you can get stainless, the steel variety rust out to quick and leaks severely. I have never done it for a skid but on our larger equipment we have had pipe bent up or bought elbows and cut them to the correct angle to fab up exhaust for the float truck (ford was 2200.00, we made ours for 600 worth of parts and a days welding. and for the skidders. I also did one for the 16 hp onan in our miller welder, 300.00 for a new muffler, I just cut it open and built one from a couple different diameters of pipe with the same design. I had to drill alot of hole in the inner pipe to make a baffle, but 10 years later its still going. Do call a few different dealers as prices on oem parts do vary alot. I have had good luck with [URL='http://www.BarronSupplyco.com']www.BarronSupplyco.com[/URL] in Barron Wi Ken [/QUOTE]
Verification
Post reply
743 cooling system
