743 build date
newy1234
I have noticed this date etc scratched into the side of the plastic fuel tank, I assume it is the build date?
Test 2
http://i256.photobucket.com/albums/hh187/newy1234/Bobcat/DSC00852.jpg
Ok, I am trying to get pics I am posting to work, but I copy the img code in from photo bucket, which I do on all the other forums I subscribe to, but it seems a no go here??
Something else I have noticed is, I can not edit any posts I make???
I host my own ftp server for posting photo's so I don't use photobucket or similar services but if you want to get around any problems posting photo's you can try this...
When composing your post click on the image icon above the post entry panel and insert one of the standard images (not one of the emoticons but one of the full images). Once you have one of the standard images inserted in your post, switch to HTML mode by clicking the HTML icon below the post entry panel and you will see the exact code required to get the image to display. Look for the entry src=” and replace all of the contents between the “ “ with the code from photobucket. I don't know the exact format photobucket is using but it should be in a form similar to http://www.photbucket.com/ImageName.jpg Make sure that you only replace the code between the quotes (“replace this code but leave the quotes“).
I don't know why you can't edit your posts... I can't either.
Oops... sorry. I see you got the copy method working while I was keying a solution to a problem you didn't have. LOL!
You can add spell check to the entry screen if you want. I think it's an addon for your browser. http://www.iespell.com/
Maybe only admins can edit posts or perhaps you need a certain number of posts before you can edit your posts.
All good, thanks. It took me a few goes but I figured it out.
