743 battery cable
KarlB
Can somebody send or post a picture of the right side of a 743 engine?
I have a negative battery cable from the frame just loose. It seems too small to fit onto any of the engine block bolts. The battery negative goes to the engine block.
Also, the fuel line has a clamp/support. Where does it attach to?
Thanks,
...karl
I re-wired mine, so it won't be the same. There should be an earth strap from the battery to the engine housing and one from the engine back to the frame for a ground.
For the fuel line, mine just hangs in place and wedges in next to the starter motor.
