I bought a Bobcat 743 "project" last fall. It had sat for several years with no cover on the exhaust pipe. Water got in the engine and I ended up with a complete rebuild (expensive). Anyway.. It runs great now and drive is strong forward and reverse on both sides but the lift and tilt seem weak. I finally checked the pressure at the aux port and it reads about 1500# with the right steer lever to the right, nothing to the left. I've unknowing been running it in the right position. The engine loads a little when moving the lever to the right but not much. lift and tilt work in either position. I've read that there is a pressure relief valve but I haven't found it yet. I know the pressure should be around 2500#. I guess i'm not sure where to go from here without buying a new pump that I may not need. Can I check the pressure directly at the pump before it goes to the control block/pressure relief valve.
