Bobcat Skidsteer Forums
743 after-market hydraulic fluid filter
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 20494" data-attributes="member: 82"><p>The water absorbing style filters will only remove SMALL amounts of water contamination. I had a machine that had a slight while colour in the oil, i had to change the oil about 4 times to get it to a state i was happy with. After the changes you can use a filter with desiccant (spelling) to remove any more water that may still be in there. As for pressure, your system should be no higher than say 200 PSI, your charge relief is set to about 95.</p></blockquote><p></p>
[QUOTE="Tazza, post: 20494, member: 82"] The water absorbing style filters will only remove SMALL amounts of water contamination. I had a machine that had a slight while colour in the oil, i had to change the oil about 4 times to get it to a state i was happy with. After the changes you can use a filter with desiccant (spelling) to remove any more water that may still be in there. As for pressure, your system should be no higher than say 200 PSI, your charge relief is set to about 95. [/QUOTE]
Verification
Post reply
