742B Mitsubishi 4G32 Water Assembly Question
Tango-Charlie
I ordered through Bobcat the Pipe Assembly 6632855 which as shown in the illustrated parts breakdown is a pipe about 8" long which has a 90 degree bend to the right and then is about 4" long with a built in tee on the pipe. One end goes into a short hose and nipple off the block on the rear of the water pump. The other end where the tee is connects to another hose back to the intake manifold and the other part of the tee is usually capped off. A good breakdown is shown in the bobcat parts breakdown at the bobcat parts online website under Model 742 serial number 509418001 & Above - Power Unit - Water Pump. I ordered the pipe assembly 6632855 as shown in the diagram and when the part came in it looked like the pipe without the built in tee and had a couple extra 45 degree bends in it. So it wasn't the pipe that I wanted with the tee and caps to help facilitate the addition of the Perrin Heater Plumbing Kit. Anyone else had this problem or any recommendations on finding the correct pipe? Thanks in advance for the help.
