Hello, I have a Bobcat 742B with the Mitsubishi engine. It just recently started making a grinding noise from the govenor box. Question is where can I get one at a decent price? My local dealer wants over 300 dollars for a new one. Thank you, Mike
Well I pulled the oil level check plug and there was a little bit of metal shavings on it. The govenor also took quite a bit of fluid for the size of it. I am guessing there wasn't much in there before.Can it simply be a bad bearing? a new set shouldn't run you too much.
Sadly, they aren't that common. You may be lucky enough to pick one up cheap. but don't hold you breath.
Sadly, the damage is probably done, you will need to look at bearings, hopefully thats all it will need.Well I pulled the oil level check plug and there was a little bit of metal shavings on it. The govenor also took quite a bit of fluid for the size of it. I am guessing there wasn't much in there before.
Alright, Thanks.Sadly, the damage is probably done, you will need to look at bearings, hopefully thats all it will need.
