742B Bobtach Dust Seals in between Lift Arms and Bobtach
Tango-Charlie
I have a question for all you Bobcat 742B experts. My Bobtach has a little side to side play and I was ordering washers to shim it and take some of the slop out. However, my Bobtach has the rubber seals and dust caps in between the Bobtach and lift arms. I went online and searched my serial number and the parts diagrams don't show any dust caps or rubbers seals other than for the tilt lift ram. Can anyone enlighten me on where to get substitutes or what to do with the old caps and seals when I tear it apart to shim the slop out. I'll also check the tapered pins to see if they are worn at the same time. But if anyone has part numbers for the caps and rubber seals that would be a starting point for me. Thanks, JD.
