742b bobcat drive pump rebuild
skidzee
So I bought a seal kit and a new rotating group for right side of tandem pump on my bobcat 742. The model is 5018 15001 and above. I removed ta dem pump and pulled apart ,cataloging every thing as I went. I was expecting seals and mostly O rings to reveal themselves but I bought a kit from LPS ( loader parts source) which came with 2 gaskets for each side of manifold 1 larger o ring for main vane pump to right side pump ( these I found a d know where they go.) The kit also came with 5 - 3.6mm 1 1/8" , 4- 3.2 mm 2 1/4" , 2- 3.2mm 2 5/8" , and 1- 2.5mm 3/4" o-rings and the main shaft seal. So where are these o rings suppose to go? Anyone have a blow up with part listing for this? Any help or info would be greatly appreciated.
Thanks all good. You were correct. That was exactly what I was looking for.
Glad I could help.
Before I do any work on a machine I always check the parts catalog. The old catalog was better but we have to make do. They used to not have an online catalog because they wanted you to go to the dealer or buy a parts catalog.
