742 Hydrostatic Hose Leaks
Dmc10140
In my continuing 742 saga, i noticed the metal with the rubber hose ends hydrostatic lines are both leaking. Wish they could have been just the short rubber ones. Am i able to just replace them with all rubber or do I need to go to bobcat to order replacements? I wish they would have flared the one end so the rubber hose portion was replaceable.
If you can fasten the hose so it doesn't rub though and can make the bends a hydraulic hose will be fine. You could even use 2 shorter hoses with elbows to get around things
