Bobcat Skidsteer Forums
742 hydraulics whining
Reply to thread
Message
<blockquote data-quote="spring" data-source="post: 27081" data-attributes="member: 2682"><p>Thanks for the replies guys. I've been away for a while but back to working on the Bobcat. About the whinning, i noticed it makes the noise at any rpm and will only stop if I move the sticks but when i do the skidsteer will creep so I don't know if adjusting it will solve the problems. I changed the oil and filter thinking that may solve the issue but it doesn't. As for the parking brake, it looks like it is at the end of its adjustment so i will have to take it apart and see how to gain some additional adjustment so to answer your question about it stopping when the p brake is on, i will need to dive into that. Any more thoughts? Also is changing the chain case fluid difficult on this machine? Also I syphined the fluid from the hydo tank should I have gotten more out in some other way? I'm all ears. Thanks, Mike</p></blockquote><p></p>
[QUOTE="spring, post: 27081, member: 2682"] Thanks for the replies guys. I've been away for a while but back to working on the Bobcat. About the whinning, i noticed it makes the noise at any rpm and will only stop if I move the sticks but when i do the skidsteer will creep so I don't know if adjusting it will solve the problems. I changed the oil and filter thinking that may solve the issue but it doesn't. As for the parking brake, it looks like it is at the end of its adjustment so i will have to take it apart and see how to gain some additional adjustment so to answer your question about it stopping when the p brake is on, i will need to dive into that. Any more thoughts? Also is changing the chain case fluid difficult on this machine? Also I syphined the fluid from the hydo tank should I have gotten more out in some other way? I'm all ears. Thanks, Mike [/QUOTE]
Verification
Post reply
