Bobcat Skidsteer Forums
742 ford engine carburator adjustment
Reply to thread
Message
<blockquote data-quote="OldMachinist" data-source="post: 36578" data-attributes="member: 437"><p>I looked in the Bobcat service manual for the settings but it wasn't in there. I then looked in my Ford tractor manual and it says 1-1 1/4 turns for the power and 1 turn for the idle and then do the start it and do the adjustments.</p><p>Idle mixture turn in till engine begins to run rough and back out to smooth idle.</p><p>Adjust Idle speed 850-950 rpms from the Bobcat manual</p><p>Adjust the main needle at full throttle turn in till speeds starts to drop and then out til runs smooth.</p></blockquote><p></p>
[QUOTE="OldMachinist, post: 36578, member: 437"] I looked in the Bobcat service manual for the settings but it wasn't in there. I then looked in my Ford tractor manual and it says 1-1 1/4 turns for the power and 1 turn for the idle and then do the start it and do the adjustments. Idle mixture turn in till engine begins to run rough and back out to smooth idle. Adjust Idle speed 850-950 rpms from the Bobcat manual Adjust the main needle at full throttle turn in till speeds starts to drop and then out til runs smooth. [/QUOTE]
Verification
Post reply
