Bobcat Skidsteer Forums
742 bogs down when traveling forward or back
Reply to thread
Message
<blockquote data-quote="turbo930ss" data-source="post: 38840" data-attributes="member: 4256"><p>Thanks again for your help. The aux, stick is off and the brake is off. The previous owner had the same problem and I drained and replaced the gov. oil at rebuild. Doesn't the return oil go thru a check valve? That's what it looks like on the hyd. diagram. Thanks Scott</p></blockquote><p></p>
[QUOTE="turbo930ss, post: 38840, member: 4256"] Thanks again for your help. The aux, stick is off and the brake is off. The previous owner had the same problem and I drained and replaced the gov. oil at rebuild. Doesn't the return oil go thru a check valve? That's what it looks like on the hyd. diagram. Thanks Scott [/QUOTE]
Verification
Post reply
