[email protected]
- Joined
- Jan 10, 2015
- Messages
- 40
Following recent post about the carb, I found that Bobcat can get me a new one--for $1200. Plan B was to get another Walker rebuild kit from O'Reilly, and it is in, and seems to work OK. I also recently put in new plugs, points, & condenser, which was also helpful. The machine now starts and runs, but I know the carb needs adjusting--idle mixture screw. Before adjusting the carb, I want the engine properly timed. All four plugs seem to be firing as expected, the engine responds to the throttle and the choke, but there is still just a hint of a skip. After removing the big belt guard to view the entire crank pulley, I find the timing to be about 90 degrees BTDC if the divot on the face is the timing mark--there is no notch. The last time the crank pulley was off was several years ago at the dealership. It doesn't seem logical that this pulley could be attached to the crankshaft in any more than one position. This would seem to be an elementary automotive challenge, but I am baffled. Any thoughts are welcome.
