742/743 Rear light -- and air in line
jerryo1314
I took out the rear light thinking it was a sealed beam light. I found the back of light looked red but not sure why their is a parking light in there.The parking light fixture is to rusted. Not sure why that is there unless it glows to the red fixture. I ran out of time but did see this setup in the manual. Do I need the parking light? I also don't recall that light as red when it was working. Second I put in a cooler for the hydraulics because it had a leak, now I seem to have air in the system. Will it self remove or do I have to relief it some where? Thinking I can loosen a hose to the filter if need be? BTW if you want to keep mice out of the Bobbie sprinkle powered Borax around. You can buy it in any store where the soap power is located. I use it in the garage, cars and basement.! Jerry
my 632 had a light like that , it was a combination work light and tail light with different positions on your light switch to change from white to red.
