732 questions
mxdadd
I have a 732 i purchased, I was in the process of putting new points, condenser, cap, & wires on I checked the vacuum advance pot to see if it was working, it did not. I tried to locate just the pot, but no one had one, or could get one, so I tried to get a whole new distributor, from what we can tell, it seams to be the same as a 1972 pinto. Does anyone know if this is correct? Also i have to pull and push the steer handle a long way to get them to respond. Is there an adjustment for these, also is there an adjustment on the foot pedals? Thanks, Matt
If that is the ford engine, I had the same problem with a 632. Could not get a vacuum advance so I went to the salvage yard and found the exact same thing on a volkswagen jetta dist. So it was not manufactured just for ford.
Jerry, Thanks for the info. You dont happen to know what year Jetta that came off of do you? Thanks, Matt
I dont know what year the jetta was matt, I tried the auto parts stores also with no luck. I did not check with a ford tractor dealer though. Members here have said that engine is the same as from a english ford fiesta from the early 80's. It was just luck I found one in the salvage yard. Maybe try to track down the dist maker. Also search these forums for a person who has rebuilt the ford engine they may have better information than me. good luck
Jerry, Thank you for your help!
