731 Shuts down
731 Warrior
My 731 shuts down automatically and I think I know what does it...just want to find out if anyone with a 731 is suffering the same problem and how they fixed it. After operating under load for about 15 minutes, the motor stops. I noticed that that the motor runs forever when not under a load (moving or using the bucket). Is there some sensor I need to replace or something? Thanks for the help...
Does it slowly bog down and die?
I suspect its a clogged filter or pickup tube. Check or replace your fuel lines all the way back to and into the tank. Replace your fuel filter too.
When its running its using more fuel than when its sitting still.
Tazza, Thanks for the reply. It does slowly die down, but sounds like it is shutting down normally...as if I pulled the throttle back to the off position. I checked the fules lines all the way back to the fuel tank and they are clean. I can't tell if it's using more fuel than normal...changing the throttle position seems to work fine.
