Atilathehun99
- Joined
- Dec 17, 2011
- Messages
- 124
I was plowing the drive yesterday and noticed they hydraulics getting weak. At first I didn't think much of it as they've always been slow in cold weather. Finally it essentially quit responding; no hoist, no bucket curl, no drive motors. I checked the hydraulic oil as it does have a leaky wheel seal. It took about 9 quarts to bring the level up to drip from the fill check plug. Today I went out to see if that did the trick and nothing. Little to almost no response from the hydraulic system. It will move a little bit, the hoist will raise a little bit and a little bucket curl. The unit is equipped with a petcock on the hydraulic line near the radiator. This was put in to bleed air from the system. Currently when the valve is open I get neither hydraulic fluid nor air. Do you think the main pump is shot perhaps due to running it with low fluid level?
