Bobcat Skidsteer Forums
643 Radiator leaks
Reply to thread
Message
<blockquote data-quote="OldMachinist" data-source="post: 34792" data-attributes="member: 437"><p>Yes the air will work its way out. Just drive it around a little at half throttle lifting, lowering and tilting the bucket. Don't hit the limits of bucket travel or you'll cause cavitation. Then let it sit a couple of hours to let the air settle out of the oil in the tank and repeat until it sounds and works normal.</p></blockquote><p></p>
[QUOTE="OldMachinist, post: 34792, member: 437"] Yes the air will work its way out. Just drive it around a little at half throttle lifting, lowering and tilting the bucket. Don't hit the limits of bucket travel or you'll cause cavitation. Then let it sit a couple of hours to let the air settle out of the oil in the tank and repeat until it sounds and works normal. [/QUOTE]
Verification
Post reply
643 Radiator leaks
