My 1st Bob cat, owned it for 2 mo.s light work around the homestead, graveling drive, cleaning out an old collasped garage. about 15 hrs of use so far. I had a problem with my drives failing. Followed the 743 post about cleaning the large bronz filter in the center hose of the manifold did this. But still will not motivate. Was hauling crusher run fill to the old garage base filling it so I can pour a concrete slab, hauling material up a 15% grade, approx 200 feet travel distance, dumping and backing out with a 90 degree turn back down to the material pile. After 4 such excursions, activating the handles to back-up the the machine did not respond both handles went limp, and only the centering spring keep them in there rest position, no hydralic feel through the handles, after several attempts I got the machine backed out of the fill site, mostly it was the right side drive doing the moving, got machine back down to the flatts, and fiddled with the drive handles and occasionally I'd get a response, nothing indicitive of correct operation. Again I pulled the hose and large filter all looks pretty good to me. Last Sat. I spent the day trying to trouble shoot the problem, I don't have a manual so I may be off base with how the actual fluid flows, but I've deduced that the steel pipe from the drive pump adapter is the circulation from the pumps to the oil cooler ???, I was told the check shuttles above the drive out ports are pressure by-passes so I pulled the one above the right drive out, and all appears ok, than veiwing from the front of the machine, on the right side of the pump adapter, is another pressure relieve shuttle valve ??, I opened this up and there seemed to be a lot of built up pressure, so I'm thinking I might have a plumbing problem. Why because I hope so since both pumps seem to drop off-line symontianously, and when its working right plenty of drive power, I don't know what criteria is for condemning the drive pumps.
