Bobcat Skidsteer Forums
642B Maintance & Life Expectancy
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 47354" data-attributes="member: 82"><p>I agree with Jerry too, chain case, or at least run it and check the colour. If its white it needs changing.</p><p>I would also do all the filters, hydraulic oil, engine oil. Even some fuel additive to get any varnish that has built up out. Grease everything.</p><p>With hoses that are old, more so if it was in the sun can crack when they get used after sitting. You may need to replace the lift/tilt hoses shortly, but deal with that if it happens.</p></blockquote><p></p>
[QUOTE="Tazza, post: 47354, member: 82"] I agree with Jerry too, chain case, or at least run it and check the colour. If its white it needs changing. I would also do all the filters, hydraulic oil, engine oil. Even some fuel additive to get any varnish that has built up out. Grease everything. With hoses that are old, more so if it was in the sun can crack when they get used after sitting. You may need to replace the lift/tilt hoses shortly, but deal with that if it happens. [/QUOTE]
Verification
Post reply
