jplacz2000
- Joined
- Dec 27, 2011
- Messages
- 29
turns pretty good without bucket on front soon as you put bucket on bearly moves lack power maybee pump???motor dies down and no power
maybee governor seems to really die and then speed up when you stop the machine ive checked govorner pump ill put new fuel filter on try thatAs you mention the engine tries to die, i wonder if you have a fuel issue causing a lack of power from the engine. Does it smoke when it bogs down? is the primer bulb flat?
Is that the ford gas engine in it? Check the ignition timing if it is, that can make it act like that also and the distributor may have moved.maybee governor seems to really die and then speed up when you stop the machine ive checked govorner pump ill put new fuel filter on try that
yes it is half to look into book to see how to timeIs that the ford gas engine in it? Check the ignition timing if it is, that can make it act like that also and the distributor may have moved.
thanks again timing was off by 10 deg runs great still having trouble with steering probably should take hydrostatic out and fix wafer plates probably what it is.yes it is half to look into book to see how to time
Make sure both the vacuum advance and the mechanical one in the dist. are working right also both are known to cause problems.thanks again timing was off by 10 deg runs great still having trouble with steering probably should take hydrostatic out and fix wafer plates probably what it is.
Reason I would suspect the engine is because you say it just dies down, the governor should open and it should labor before dying.Make sure both the vacuum advance and the mechanical one in the dist. are working right also both are known to cause problems.
If you have run it with ethanol fuel you could have the problem I had. Ate up a new fuel pump in 3-months. Pump diaphragm was so stiffened up the pump would not stroke. Also a stiff pump is hard on the fuel pump eccentric lobe on the camshaft. If it has much wear there is not enough stroke to adequately fuel the engine. Finally installed an electric pump. -DickReason I would suspect the engine is because you say it just dies down, the governor should open and it should labor before dying.
