Bobcat Skidsteer Forums
642 Chaincase Over full?
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 19418" data-attributes="member: 82"><p>The way i have done it in the past was to have a pan under there and remove the plug, let it fill then put the plug back in, empty the pan then repeat. Whatever way you are happy with though. If its FULL you will have approx 25 litres extra in there, the tank holds about 25-30 to be at the rite level, so double that for FULL.</p><p>The breather is like a bronze screen thats under the bar that runs across the chain case that links to the lift pedal, you won't be able to see it unless you remove this bar, its also under the hydro pumps so you can't get to it. Its not something you will need to service anyway. I think there is another one under your park brake, but not all models have this.</p><p>I hope that helps you a little bit.</p></blockquote><p></p>
[QUOTE="Tazza, post: 19418, member: 82"] The way i have done it in the past was to have a pan under there and remove the plug, let it fill then put the plug back in, empty the pan then repeat. Whatever way you are happy with though. If its FULL you will have approx 25 litres extra in there, the tank holds about 25-30 to be at the rite level, so double that for FULL. The breather is like a bronze screen thats under the bar that runs across the chain case that links to the lift pedal, you won't be able to see it unless you remove this bar, its also under the hydro pumps so you can't get to it. Its not something you will need to service anyway. I think there is another one under your park brake, but not all models have this. I hope that helps you a little bit. [/QUOTE]
Verification
Post reply
