632 bobcat
larryk50
i seem to have a chatter in the drive train now that I got my machine to rev up to operation speed. I don't have a manual on the proper fluid that the hydrostatic chains will take or the proper level of fluid . do you check the level on the front of the machine where I drain the fluid? still working on the governor to make it smooth out . but each day it gets a little closer. any suggestions?
The plug in the front of the chain case is the fill/ check level hole. When you take it out oil should not run out. There is no drain. 10-30 motor oil is the fluid.
what would be the capacity for the oil in the drive chain?.. I only put 2 qts in to move the machine into another garage, it has helped the chatter but Im not sure how much I should put in.. , I have sent away for a manual so I don't have to ask such dumb questions. finally got the machine to run and govern out right, seems like a nice little unit, hope to keep it going for some time. any help will be appreciated
With machine on a level surface you fill it till it just starts to run back out of the fill hole. The 632 chaincase holds 5 gals.
