WELL WITH ALL THE HELP I RECIEVED I GOT THE 1.6 FORD MOTOR IN THIS BOBCAT TO FIRE AND RUN.. BUT ONLY AT AN IDLE.. I TOOK THE CARB OFF AND DID A CLEANING AND CHECKED THE ANTI DESILING VALVE TO MAKE SURE IT WAS WORKING.. THE MACHINE WILL RUN AT AN IDLE BUT WILL DIE IF YOU TRY TO GET IT TO REV UP.. I HAVE HAD IT BACK FIRE AND CAUSE A SHORT FIRE FROM MAYBE TOO MUCH FUEL , BUT IT SEEMS TO ONLY RUN WHAT IS PUT IN THE BOWL OF THE CARB. IT HAS A NEW ELECTRIC PUMP AND IT IS GETING FUEL. I HAVE BEEN ABLE TO MANUALLY GET IT TO ALMOST REV UP BY BEING AT THE BACK WHILE SOMEONE STAYS IN THE CAB TO CRANK IT .. BUT THIS IS WHEN I CREATE FIRES.. THE CARB DOESNT SEEM TO HAVE ANY REAL ADJUSTMENTS OTHER THAN THE AIR MIXTURE.. IS THERE OTHER THINGS I SHOULD BE LOOKING FOR OR MAYBE A TRICK TO GET THE THING TO REV UP TO MOVE IT OUT OF MY SHOP SO I CAN HAVE SOME SPACE BACK.. IM GETTING OLD TRYING TO FIGURE THIS OUT.. HELP!!! IT FIRST JUST STARTED OUT NOT HAVING ANY SPARK. BUT SINCE WE HAVE FIXED THAT PROBLEM I JUST CANT SEEM TO MAKE THING WORK...
