blazer81.6
- Joined
- Dec 5, 2017
- Messages
- 5
Hello Guys: I need a little help with my 632 BobCat, Ford Gas Engine. The skidsteer operates good, beside the front right tire. I was running it and noticed the front right doesn't pull. It will not operate going forward or backwards. I did notice the right rear tire operates fine. It has me puzzled, not knowing if it's a broken drive chain on that side? When I purchased the steer, someone had the hydro lines hooked up incorrectly. You had to push the levers backward to go forwards. If you wanted to turn right, you pushed the right lever. Anyway, I have the lines ran where everything operates correctly, besides the right front tire. Any help would be greatly appreciated.
