631 I am in Australia I assume the same machine the world over. Some previous owner has done some shoddy work before me. My spool valve bank from top down:- pressure inlet, TILT, has detent LIFT, has detenf AUX, no detent pressure out to valve block. My understanding in the RHS control lever also operates the AUX (bucket open/close/ attachments) so to have permanent flow to an attachment (backhoe for example) shouldn’t there be a detent on the bottom spool valve? I made a call to bobcat here in Aust and they said it was changed. to AUX,LIFT,TILT. So it sounds like I have the linkages for the older setup TILT,LIFT,AUX but a newer spool that's meant for AUX,LIFT,TILT Does any of this make sense? My plumbing and linkages go:- TILT, LIFT. AUX but the spool appears to be for a :- AUX, LIFT, TILT So when I re-install the spool valve I suppose I should re-arrange the linkages to suit AUX,LIFT,TILT, and re-plumb the hoses and pipes accordingly. One concern is that the AUX spool with the detent (on the top) should be able to accommodate a flow rate suitable for an attachment that needs it. My pedals are LHS-LIFT, RHS-TILT is this correct for a 631? cheers, Shane, Brisbane , AU
