Bobcat Skidsteer Forums
610 dying on me
Reply to thread
Message
<blockquote data-quote="OldMachinist" data-source="post: 53976" data-attributes="member: 437"><p>On some Wisconsin engines there's a safety switch on one of the heads and if it gets too hot it grounds out the coil. Easy way to tell if yours has the switch is if you have a extra wire coming off the coil that goes into the sheet metal shrouding. If the switch is cutting off the ignition you need to remove all the sheet metal and clean the cooling fins.</p><p>Next thing to do is a complete tune up(points, condenser, wires, coil and spark plugs)</p></blockquote><p></p>
[QUOTE="OldMachinist, post: 53976, member: 437"] On some Wisconsin engines there's a safety switch on one of the heads and if it gets too hot it grounds out the coil. Easy way to tell if yours has the switch is if you have a extra wire coming off the coil that goes into the sheet metal shrouding. If the switch is cutting off the ignition you need to remove all the sheet metal and clean the cooling fins. Next thing to do is a complete tune up(points, condenser, wires, coil and spark plugs) [/QUOTE]
Verification
Post reply
610 dying on me
